Hotend and firmware issue
G.Gears
(@g-gears)
Hello everyone,
My nozzle no longer heats up , I tried several thing but nothing work. I change my all hotend. I think the problem is from my Rambo, but I can’t update it either. I have tried several times unplugged/reconnected all cable but the problem persists. What can I do to find a solution ?
Bonjour à tous,
Je ma buse ne chauffe plus , j'ai tout essayé mais rien à faire. J'ai remplacer toute la partie chauffante. Je pense que le problème viens de ma rambo mais je n'arrive pas non plus à la mettre à jour. j'ai tenter plusieurs fois de tous débranché/rebranché mais le problème persiste. Que puis-je faire pour trouver une solution ?
Publié : 07/04/2019 7:53 pm
Re: Hotend and firmware issue
Use an Ohm Meter to measure the heater and thermistor. It appears that one of them has failed and no longer working properly. If you recently changed ALL the hotend parts, then try plugging in the OLD heater and thermistor (no need to reassemble, just power things off: and plug in the old parts, power on and run the selftest).
Publié : 07/04/2019 9:10 pm
vintagepc
(@vintagepc)
Membre
You will need to put them in a heatblock together else you'll get a failure. The selftest expects to see the temperature reading rise when it turns on the heater.
Publié : 07/04/2019 11:00 pm
Vintage, thanks for the catch - forgot that small detail.
Publié : 08/04/2019 2:04 am
