					                		Help, printer jams before purge line. - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/help-printer-jams-before-purge-line/</link>
                <lastBuildDate>Wed, 10 Jun 2026 18:41:28 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/help-printer-jams-before-purge-line/#post-564091</link>
                        <pubDate>Sat, 15 Jan 2022 06:44:09 +0000</pubDate>
                        <description><![CDATA[The two things that come immediately to mind are:
1. The Z is too low
2. The grub screws on the extruder are not properly tightened
Either or both could cause it.
jwv]]></description>
                        <content:encoded><![CDATA[<p>The two things that come immediately to mind are:</p>
<p>1. The Z is too low</p>
<p>2. The grub screws on the extruder are not properly tightened</p>
<p>Either or both could cause it.</p>
<p>jwv</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jwvaughn</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/help-printer-jams-before-purge-line/#post-564091</guid>
                        <title>Help, printer jams before purge line.</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/help-printer-jams-before-purge-line/#post-564082</link>
                        <pubDate>Sat, 15 Jan 2022 05:56:44 +0000</pubDate>
                        <description><![CDATA[IMG_4867Can’t start a print, extruder clicks before purge line, i’ve tried everything i can think of, except for replacing the nozzle, or heatbreak as i firmly believe they’re fine.I’ve repl...]]></description>
                        <content:encoded><![CDATA[<p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/01/IMG_4867.mov">IMG_4867</a></p><p>Can’t start a print, extruder clicks before purge line, i’ve tried everything i can think of, except for replacing the nozzle, or heatbreak as i firmly believe they’re fine.</p><p>I’ve replaced the ptfe tube with Capricorn tubing, and heated the nozzle and heatbreak till all filament has burnt(pla), or spilled onto the heating surface, clearing all plastic, yet the extruder still clicks on the first try before the purge line after reassembly… i broke the thermistor cables earlier after many reassembles, so I’m looking for solutions as i wait for a new one. Yes, I have messed with the idler screw, it is not that, and the gears are also aligned properly.</p><p>i have the heatbreak with the 2.2 bore, and have also ordered a normal one, but can’t see that being my issue, as all plastic melts away during my cleaning…. So i it should be freed up to at least print a layer right.? Filament goes through heatbreak fine when taken out, even before it’s cleaned for another try.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Markus</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/help-printer-jams-before-purge-line/#post-564082</guid>
