					                		Heater cartridge loose fit heaterblock - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/</link>
                <lastBuildDate>Fri, 10 Apr 2026 23:51:52 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-617397</link>
                        <pubDate>Tue, 16 Aug 2022 11:53:20 +0000</pubDate>
                        <description><![CDATA[In that case see]]></description>
                        <content:encoded><![CDATA[<p>In that case see:</p><p>https://help.prusa3d.com/guide/how-to-replace-a-heatbreak-heaterblock-heatsink-mk3-mk2-5_14944#15704</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-617397</guid>
                        <title>RE: Heater cartridge loose fit heaterblock</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-617355</link>
                        <pubDate>Tue, 16 Aug 2022 04:20:11 +0000</pubDate>
                        <description><![CDATA[The screw started to strip and i can&#039;t get it tighter but it falls out when hold sideways.If I’m not mistaken, the thermistor is ‘pinched’ in its slot by that screw.If you have a small drill...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="0" data-postid="616934" data-mention=""><p>The screw started to strip and i can't get it tighter but it falls out when hold sideways.</p></blockquote><p>If I’m not mistaken, the thermistor is ‘pinched’ in its slot by that screw.</p><p>If you have a small drill and tap, you can gently drill the threads out and tap new threads for a nominally oversized screw. You’ll also have to drill an oversized hole for the screw clearance (before you tap the new threads) where the screw first enters the heater block.</p><p>The heater block is aluminum so this should be pretty straightforward.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>RandyM9</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-617355</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-617274</link>
                        <pubDate>Mon, 15 Aug 2022 12:26:32 +0000</pubDate>
                        <description><![CDATA[No, i am not following those instruction since they are about replacing an whole new hotend and i am having issues with the heater cartridge specifically. As in i am assembling a new complet...]]></description>
                        <content:encoded><![CDATA[<p>No, i am not following those instruction since they are about replacing an whole new hotend and i am having issues with the heater cartridge specifically. As in i am assembling a new complete hotend.</p><p>Thank you for the reply tho.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Luuk Liesdonk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-617274</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-616945</link>
                        <pubDate>Thu, 11 Aug 2022 13:23:36 +0000</pubDate>
                        <description><![CDATA[Are you followingfrom step 9Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>Are you following:</p><p>https://help.prusa3d.com/guide/how-to-replace-a-hotend-mk3s-mk3s_161575</p><p>Check from step 9</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-616945</guid>
                        <title>Heater cartridge loose fit heaterblock</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-616934</link>
                        <pubDate>Thu, 11 Aug 2022 11:34:20 +0000</pubDate>
                        <description><![CDATA[Greetings all:I have a small issue with my Prusa MK3s+.I was replacing my heater Cartridge, thermistor and heaterblock after wrecking them while cleaning a failed print.The new parts (all or...]]></description>
                        <content:encoded><![CDATA[<p>Greetings all:</p><p>I have a small issue with my Prusa MK3s+.</p><p>I was replacing my heater Cartridge, thermistor and heaterblock after wrecking them while cleaning a failed print.<br /><br />The new parts (all original Prusa parts) came in and while installing the new heater cartridge it was a pretty loose fit. <br /><br />The screw started to strip and i can't get it tighter but it falls out when hold sideways. There is nothing to find on this issue and i dubble checked if i got the right parts. </p><p>Any help and tips are welcome!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/heater-cartridge-loose-fit-heaterblock/#post-616934</guid>
