Heater Cartridge Connector
Daniel Weitz
(@daniel-weitz-2)
I am replacing a defective heater cartridge.  The replacement sent by Prusa lacked the quick-connector. I am unable to unscrew the two screws that held in the old wires. What is the term for this quick connector? How may I obtain a new connector?
Respondido : 10/10/2019 4:18 am
Bunny Science
(@bunny-science)
RE: Heater Cartridge Connector
It is a 5.08mm Pitch 2P Pluggable Terminal Block Connector
These aftermarket ones work despite the green color
https://www.amazon.com/gp/product/B01F4F5BPY
Esta publicación ha sido modificada el hace 7 years por Bunny Science
Respondido : 10/10/2019 9:44 am
Daniel Weitz
(@daniel-weitz-2)
@guy-k2
Many thanks for your advice; just ordered the connectors.
Any advice on heater cartridges sold by Amazon?
Respondido : 10/10/2019 2:20 pm
Hi Dweitz,
Some would say that there is no guarantee of the quality of the Amazon heaters...
that's a decision for you...   I have used Ebay heaters, and still have a house that hasn't burned down and printers that still work...   🙂
I understand that you have a Mk3 or Mk3S printer...
that is a 24 volt printer...
MAKE SURE THAT YOU GET 24 Volt heaters!!!
the Prusa Mk3/Mk3s uses a 40Watt 24 volt heater...
IF you get the 12 volt heater, it will try to use 4 times the power that it's supposed to use... and if you are lucky, the Einsy heater fuse will blow, and disconnect the power before anything more serious happens....  !
Take care!
Respondido : 10/10/2019 2:46 pm
