Heat Block Thermistor Grub screw size?
robert.b52
(@robert-b52)
My thermistor went bad, so I ordered a replacement. Unfortunately, while removing the old one, I stripped the grub screw. I was able to get it out, but I do not want to reuse it. What size is the mk3 thermistor grub screw so I can grab a replacement?
I had to use a 1.5mm wrench to pop it out. Measurements are showing 2.9mm diameter x 3.9mm length.
Posted : 28/04/2018 3:37 am
keithywhites
(@keithywhites)
Re: Heat Block Thermistor Grub screw size?
by the looks of this , it looks like m3 X 5mm or something
Posted : 28/04/2018 3:57 am
