Heat bed height difference (left lower than right)
- I moved my printer recently. After sat it up in the new house, and did the PINDA calibration, and XYZ calibration I noticed the right side of the bed being higher up than the left side compared to the nozzle. Can the z-axis stepper motors have been pushed up more on the right side compared to the left. When I placed it on my car seat I noticed the z-motors being in contact with the seat because of the seats shape. The height difference between the left and right side of the bed and the nozzle is the same no matter where the y-axis is, which makes me believe it's the stepper motors for the z-axis which is skewed. Should I dismantle the whole printer and put it back together again? What do you think I should do?
This topic was modified před 11 months 2 times by SailorAtSea
Napsal : 06/12/2024 11:56 am
RE: Heat bed height difference (left lower than right)
If you calibrate the Z Axis (NOT LIVE Z) the printer should run the X Gantry to the top of the Z axis, and then it should stall both Z motors against the Z axis end stops,
after this, the X axis gantry should be level
Auto Home, should bring the X axis Gantry (And nozzle) back down
Napsal : 06/12/2024 12:02 pm
1 lidem se líbí
