Page 3 / 3
Prev
RE: Grounding the printer
If touch " earth ground" , before you touch the printer.
This is not needed on your printer, before you want to do something on your printer, touch somewhere the earth grounding , it could be a extra cable, a different hardware which is grounded.
if you work on pc hardware, you should put on shoes(not bear foot), and touch the plastic bag and the earth grounding, then you can start the pc repair.
Best thing to do is , touch earth grounding, and put on shoes, that's all.(i would first try only touch grounding).
Also something to test, if you printer is touching other hardware, are these OK, use the printer without other hardware and see if it is gone, defective hardware could also do this.
Posted : 25/05/2020 8:09 am
Page 3 / 3
Prev
