Good news Higher density mesh bed leveling coming
Page 2 / 3
ed
 ed
(@ed-3)
Re: Good news Higher density mesh bed leveling coming
OTOH, maybe Prusa sees this as a solution to poor yields on their textured sheets.
Mesh bed levelling is not going to make any difference if this is the case since the PINDA works on the flat steel sheet not the PEI surface coating.
From my experience, most of the irregularity requiring mesh bed levelling comes from the heatbed which flexes as the temperature changes and not the textured PEI sheet.
Now if the Calibration Bed level correct points were increased to match the 7x7 or 9x9 quantity, that would be a complete new ball game and allow for perfect first layers, but I don't think there is enough memory capacity to be able to do this unless PRUSA find some way of maybe storing the lookup table on say the SD card.
Hmmm, If there is a yield issue with irregular thickness of the coating, then if an SD compensation map file were used, then each sheet could be sent out with a QR code which has a link for the compensation map for the surface, this could then be downloaded to the SD card.
3rd party sheets would not have this, so would be less desirable.
However, if the coating is uneven on the bottom side of the build plate it will affect the flatness of the steel sheet which will effect the PINDA readings... The surface of the PEI stickers are uniform and the powder coating is much more difficult to maintain a uniform thickness across the sheet. At least I'm assuming surface uniformity is what's causing poor yields on the PC sheets. I know the two after market PC sheets I own have high and low spots on them and the 7x7 makes a world of difference to the first layer on them.
Publié : 15/01/2019 3:12 pm
imod.systems
(@imod-systems)
Are you guys really suffering from the current levelling? I fully agree it's always better to have a perfectly levelled bed but I'm using always 0.2mm for the first layer and was never a big thing for me.
Yes, especially when you have to fill and entire build plate of prints to fulfill orders that require an immaculate and consistent first layer
This picture is a print that’s still in the dialing in phase. There’s still some imperfections that were being fixed:
Here’s an example of a print that required a perfect first layer that I dialed in:
Publié : 15/01/2019 3:44 pm
Nikolai
(@nikolai)
Can you set different layer heights using Slic3rPE ?
Yes, first layer and other layers can be set differently in Slic3r PE. Most of the slicers allows it.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Publié : 15/01/2019 4:16 pm
Spacemarine
(@spacemarine)
That photo is blurred, so it's hard to say anything about the layer quality.
Publié : 15/01/2019 11:42 pm
Spacemarine
(@spacemarine)
Here is a good example of the benefit of 7x7 vs. 3x3 leveling.
As you can see, the outer points are all pretty level, so when you look only at these and interpolate in between, you totally miss that bump in the lower right corner. I always have that bump, even if I measure multiple times and rotate the sheet.
I leveled the bed with the screw mod, but I can't remove this bump. Hopefully, it will be fully compensated for by the firmware.
Publié : 15/01/2019 11:50 pm
Nikolai
(@nikolai)
You have less then 0.1 variance through the whole bed. Most people just dream of that 🙂
Often linked posts:
Real Multi Material
Publié : 15/01/2019 11:54 pm
imod.systems
(@imod-systems)
That’s actually not a blur. That’s the light reflecting off of a completely solid looking first layer. Here’s a picture from another angle
Publié : 16/01/2019 5:33 am
toaf
 toaf
(@toaf)
much better picture, at least we can see lines now 😀 thanks
Publié : 16/01/2019 5:39 am
Bunny Science
(@bunny-science)
Without that last picture, I was totally amazed at how you managed to remove such a large, perfect, thin sheet from the print bed.
Publié : 16/01/2019 5:46 am
toaf
 toaf
(@toaf)
as long as its a few layers just let the build plate cool. they come right off
Publié : 16/01/2019 6:10 am
Spacemarine
(@spacemarine)
It actually is blur. You can see that the camera focussed on the backround, which is sharp. The finger next to your first layer, is totally blurred.
But your new two photos are very nice!
Publié : 16/01/2019 10:04 am
Phil
 Phil
(@phil-4)
Is there any way for me to try this without joining FB? I don't have an account.
Publié : 18/01/2019 2:29 am
ed
 ed
(@ed-3)
There are multiple variations in this thread, pick your poison...
https://github.com/prusa3d/Prusa-Firmware/issues/1239
Publié : 18/01/2019 4:30 am
kenr
 kenr
(@kenr)
Refining the bed leveling routine sounds promising
Possibly that partially explains why ABS prints consistently lift on the left hand side of bed.
Print Setup:
Initially located the print in the middle of bed. Print lay flat size 5 (127mm) x 3 (76mm). Filament MakeShaper 1.75mm ABS. Nozzle 0.45mm. Started with Slic3r PE recommended settings for ABS. Built an enclosure around three sides of the printer 24 (610mm) width x 24 (610mm) depth x 24 (610mm) tall, cleaned PEI sheet with Acetone, Alcohol, Windex glass cleaner (no improvement)
Purchased a Fluke model 62 Max + temperature sensor and mapped the surface temperature of bed. The temperature variance across the surface in my opinion is considerable.
Bed Temperature Measurements (temperature setting 100C)
Rear left to right 97, 100 96
Center left to right 101, 99, 97
Front left to right 99, 102, 98
Bed temperature variance 6C
Orienting the part in areas of the bed with a more constant temperature reduced the amount of lift.
Increasing the bed temperature 10C reduce the lift further (above the recommended value)
Are there other techniques that I should be exploring to resolve the lift problem?
Thank You,
Publié : 12/03/2019 1:48 am
3Delight
(@3delight)
Modérateur Moderator
7 x 7 Mesh Bed Levelling now released in the new 3.7.0-RC1 Firmware, available on the GitHub site: https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.7.0-RC1 .
Publié : 16/03/2019 5:08 pm
vintagepc
(@vintagepc)
Membre
I was wondering when we'd see an RC with that feature... Guess I know what I'm doing once my current print finishes... 🙂
Publié : 16/03/2019 6:17 pm
ed
 ed
(@ed-3)
Am I the only one getting crash detected errors with the 3.70 RC1 firmware as a mesh bed level and completes?
Publié : 16/03/2019 10:26 pm
ed
 ed
(@ed-3)
I I think I found the problem my noctua fan wires weren’t tucked in all the way.
Publié : 16/03/2019 11:21 pm
OmegaPax
(@omegapax)
I'm getting a forced z calibration in middle of the mesh bed leveling process at random points after updating to this firmware. This is happening to 4 of my 8 printers. Everything was fine before. Any ideas?
Publié : 22/04/2019 6:10 pm
Vous a aimé
GeorgeE
(@georgee)
RE: Good news Higher density mesh bed leveling coming
Posted by: michael.p55
Have you updated to the released version of firmware? The first beta version posted gave me the same problem until I set the number of samples for each point to 1. The released version operates with 3 samples but if the first fast sampling fails on a point (too much variation between each sample) it falls back to the older slow sampling method for that point, this allows any vibrations to settle down a bit before the next sample.
Publié : 26/04/2019 4:50 pm
Page 2 / 3
