Getting a warning about gcode being for a different printer
Scott Clemence
(@scott-clemence)
I upgraded the firmware to 3.12.2 and am using PrusaSlicer 2.5.2 and specify the printer as "Original Prusa i3 MK3S & MK3S+" (which is what I have).  What would be causing this warning to come up stating the print is for a different printer?  It didn't start doing that untill after I upgraded the firmware.
Dieses Thema wurde geändert Vor 3 years 2 mal von Scott Clemence
Veröffentlicht : 18/04/2023 3:16 am
RE: Getting a warning about gcode being for a different printer
Hi Scott,
Could it be that you loaded the wrong firmware, say the mk3  or mk3S firmware?
Veröffentlicht : 18/04/2023 6:15 am
Scott Clemence
(@scott-clemence)
Thanks.  I can't believe I actually did that but I went and verified what firmware I downloaded and sure enough, it was the MK3 and not the MK3S+.  I have reflashed it with the correct firmware and that warning is gone now.
Thanks.
Veröffentlicht : 18/04/2023 2:52 pm
You're not the first, and you won't be the last to do that!
Joan
Veröffentlicht : 18/04/2023 5:52 pm
