gcode issue with PrusaControl vs Slic3r
Hello,
I'm a beginner with the printer and after assembling it is printing like a charm. I decided to stop printing the gcodes present in the SD card for something I had. As it was recommended I used PrusaControl to generate the gcode from the stl file. But something weird happened. So the model is quite an easy geometry, but the gcode put a hole that it shouldn't be there. I saw it while it was printing. The strange thing is that this doesn't happen when I use slic3r, is this a bug or is there something wrong with the stl file. I have to say, the stl file is not mine, I downloaded it from the internet.
I've added a couple of screenshots where you can easily see the issue. Not sure what could cause it but it seems that the volume is ok in the model.
The infil is correct from Slic3r:
And here you can see the square is missing in PrusaControl:
And here how it turned out from the gcode in PrusaControl:
Edit: Still amazed that it printed perfectly with the whole there 😀
