Garolite bed crashes
Page 2 / 3
RE: Garolite bed crashes
Posted by: Vojtěch
Posted by: charles.h13
Posted by: Vojtěch
  1. Buy a bare steel sheet, some 468MP adhesive, a 0.2mm or 0.5mm Garolite sheet, and make yourself your own garolite flex sheet. Or buy one pre-made.
That is fantastic.  Thanks for sharing.  I have been looking for one for months.
I cannot vouch for quality or fitness for purpose of the pre-made one, though, I have made one for myself from the Aliexpress parts.
I will order and test one.
Posted : 05/06/2019 11:09 am
Chocki
(@chocki)
Bear in mind, it's sensing range is not as good as a PRUSA sheet, and it is not as flexible, But, I get really nice first layers (Consistent and more even than a PRUSA textured sheet) on the same FYSETC steel sheet as shown in the link.
I got mine through Amazon. Arrived 3 days after ordering.
When you get it, clean it thoroughly with IPA, and use a plastic scraper working across to push any air bubbles out as you lay your sheet on top.
Try to overlap on all sides then simply run a sharp knife along the edge to trim any overhang to the steel sheet.
Posted : 05/06/2019 11:59 am
Posted by: chocki
Amazon?  which link?
Posted : 05/06/2019 12:09 pm
Chocki
(@chocki)
Ok, you were talking just the metal bed.  I think t might be worth it to by the applied one from Etsy.
Posted : 05/06/2019 1:52 pm
Quick correction: The cheap BuildTak-like surfaces I purchased were from FYSETC, but the actual "spring steel" sheet is from Blurolls. This thing is a monstrosity, and with the 2 FYSETC surfaces applied, comes in at nearly 2mm thick. I find it unusable. It sounds like FYSETC is a good choice. Others less so.
Posted : 05/06/2019 2:35 pm
Chocki
(@chocki)
I may have to check this garolyte out myself as polycarbonate WELDS to buildtack, but from a couple of reads this garolyte might be a better choice, but not 1mm thick.
Posted : 05/06/2019 3:08 pm
 Of course Voj still hasn't explained HOW he got the words to display on the screen ... too funny dude.  Useless, but funny.
Posted : 05/06/2019 3:39 pm
Vojtěch
(@vojtech)
Posted by: Tim
It works for simple gcode files that don't contain anything useful. All what I've done is I've put those two lines (M0 text and M84) that I've included in my post into a gcode file and ran that gcode file. It displayed the words. I'm sorry, I assumed that was obvious from my post.
But it breaks for anything bigger, and it looks like a firmware bug. I've spend a couple hours reading the firmware sources today, now I'm back at home and I'm going to do some debugging.
Posted : 05/06/2019 3:47 pm
Vojtěch
(@vojtech)
I found why the Prusa Marlin firmware doesn't display the M0 message. It's because the print progress status and filename display takes precedence when printing from a SD card. This M0.patch fixes the problem and messages are displayed even on long gcode files.
I still need to continue debugging, because there is another bug in the firmware that skips the M0 gcode entirely, not waiting at all.
This post was modified 7 years ago 2 times by Vojtěch
Posted : 05/06/2019 7:54 pm
In my gcode above I discovered a minor flip of data:
G0 X200 Y0 Z100 ; this is a good waiting point for bed flip
should be
G0 X0 Y200 Z100 ; this is a good waiting point for bed flip
The idea is to put the bed forward for easier handling.  And there's probably some other moves that can be helpful for cases where a user bumps the bed forward or backwards when flipping the sheet.
This post was modified 7 years ago by --
Posted : 05/06/2019 8:08 pm
Vojtěch
(@vojtech)
Debugging finished. The next bug was that the M0 command would be ignored if the text contained the capital letter 'G'. So when I tried
M0 Install Garolite!
then the printer would just ignore the statement. Plus I found another bug in M117, which I also fixed. The Marlin code is pretty crusty.
Anyway, here is the combined M0-v2.patch. Apply using
patch -p1 < M0-v2.patch
 to the checked-out Prusa-Firmware git tree, recompile, flash into the printer and the M0 and M1 commands (as well as M117) will work as they're supposed to.
This post was modified 7 years ago 4 times by Vojtěch
Posted : 05/06/2019 9:40 pm
What's your github index for the bug you entered?
Posted : 05/06/2019 9:44 pm
Vojtěch
(@vojtech)
Posted by: Tim
Well, at the moment I'm figuring out how to do that properly, hopefully including a git pull request. I'm not a github user yet.
Posted : 05/06/2019 10:00 pm
You don't need a pull request, just get an account, and post an issue; someone will eventually look at it.
Posted : 05/06/2019 10:06 pm
Vojtěch
(@vojtech)
Posted by: Tim
Well, there already was one https://ghttps://github.com/prusa3d/Prusa-Firmware/issues/1898ithub.com/prusa3d/Prusa-Firmware/issues/1898 so I just added a link to my solution.
Posted : 05/06/2019 10:19 pm
Vojtěch
(@vojtech)
And pull request done, too. https://https://github.com/prusa3d/Prusa-Firmware/pull/1900github.com/prusa3d/Prusa-Firmware/pull/1900
Posted : 05/06/2019 10:32 pm
Thanks.  Worth noting is the M117 defect is still there and my bug report for it is still hanging fruit. Maybe your sample code will be enough to get someone off their fanny to dig into and actually fix the two issues.
Sounds like another case of poor interrupt handling (pop to the vector, clear the flag, then return).  It's my guess why the filament sensor is always having issues: they appear to clear a register of interrupt flags without really knowing what the other flags are doing - even if one is pending.
Posted : 05/06/2019 11:15 pm
Vojtěch
(@vojtech)
Posted by: Tim
What number? I've searched the bug list for M117 and can't find anything matching your description.
Posted : 06/06/2019 4:43 am
https://github.com/prusa3d/Prusa-Firmware/issues/1443
Posted : 06/06/2019 5:45 am
Page 2 / 3
