FW crash detected and boot loop with 3.13.x
After flashing the 3.13.2 the printer entered a boot loop with the "FW crash detected" report. Sometimes the main screen appeared, but on the next start the error message was back. The factory reset did not change anything. I have seen the message once or twice on the previous 3.13, I don't know whether .0 or .1 anymore.
I have flashed 3.12.2 back and all seems fine. Flashed 3.13.2 again, the problem reappeared, 3.12.2 and all is fine.
This is a mk3s upgraded from mk2s in 2020, no MMU and the crash happens without any SD card nor USB cable plugged in. Anyone with the same problem? Is there anything to try? Thanks
RE: FW crash detected and boot loop with 3.13.x
Try post it here this issue is the same as yours except it happend Jan this year. https://github.com/prusa3d/Prusa-Firmware/issues/3512
I have created https://github.com/prusa3d/Prusa-Firmware/issues/4513 in the meantime. I'll add a link to the original (closed) issue.
