Full size print taking the whole X axis results this in mk3s in one side
Hi, I have a part that is supposed to use the full X axis of my printer (250mm), but I’m having an issue. The side of the part closest to the X motor came out rough, while the opposite side looks clean (see the last picture for reference).
When I measure from the center of the part to the rough side, it’s only 123mm—about 2mm short of what it should be. I ran the belt test to check the X axis range, and it showed 261mm.
I’ve checked, and the print head doesn’t hit any obstacles on the rough/short side. There’s about a 9mm gap from the home position to the edge of the limit on both side.
Any advice or suggestions would be appreciated!
Napsal : 18/05/2025 12:01 pm
