Flashing error
Hydrohydra
(@hydrohydra)
Flashing error
Hello, I get this error when trying flashing my prusa i3 mk3s. "ERROR: No valid record found in Intel Hex file"
That version number is what the printer identifies itself as in the display when the printer is on.
I am trying to flash with the file from https://help.prusa3d.com/downloads/mk3s. It is extracted and I am targeting the .HEX file. The printer is on, the cable is connected. I tried rebooting the pc and printer but no luck.
What is going wrong here?
I was a bit unsure about the version number of the printer, because I got it second hand and it was upgraded with some MMU stuff, but it was later removed, so it doesn't always match the images for identifying version, but I assumed I can rely on the printer's self report.
Here is the error report in full:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM7 -b 115200 -D -U flash:w:0:C:\Users\speed\Downloads\__MACOSX\prusa3d_fw_3_14_1_MK3S\._MK3S_MK3S+_FW_3.14.1_MULTILANG.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Nov  6 2025 at 10:47:10
                Copyright (c) 2000-2005 Brian Dean,  http://www.bdmicro.com/
                Copyright (c) 2007-2014 Joerg Wunsch
                Using Port                    : COM7
                Using Programmer              : wiring
                Overriding Baud Rate          : 115200
                AVR Part                      : ATmega2560
                Chip Erase delay              : 9000 us
                PAGEL                         : PD7
                BS2                           : PA0
                RESET disposition             : dedicated
                RETRY pulse                   : SCK
                serial program mode           : yes
                parallel program mode         : yes
                Timeout                       : 200
                StabDelay                     : 100
                CmdexeDelay                   : 25
                SyncLoops                     : 32
                ByteDelay                     : 0
                PollIndex                     : 3
                PollValue                     : 0x53
                Memory Detail                 :
                                         Block Poll               Page                       Polled
                  Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                  eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
                  flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
                  lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                  signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                Programmer Type : Wiring
                Description     : Wiring
                Programmer Model: AVRISP
                Hardware Version: 15
                Firmware Version Master : 2.10
                Vtarget         : 0.0 V
                SCK period      : 0.1 us
avrdude-slic3r: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude-slic3r: Device signature = 0x1e9801 (probably m2560)
avrdude-slic3r: safemode: hfuse reads as D0
avrdude-slic3r: safemode: efuse reads as FD
avrdude-slic3r: reading input file "C:\Users\speed\Downloads\__MACOSX\prusa3d_fw_3_14_1_MK3S\._MK3S_MK3S+_FW_3.14.1_MULTILANG.hex"
avrdude-slic3r: ERROR: No valid record found in Intel Hex file "C:\Users\speed\Downloads\__MACOSX\prusa3d_fw_3_14_1_MK3S\._MK3S_MK3S+_FW_3.14.1_MULTILANG.hex"
avrdude-slic3r: read from file 'C:\Users\speed\Downloads\__MACOSX\prusa3d_fw_3_14_1_MK3S\._MK3S_MK3S+_FW_3.14.1_MULTILANG.hex' failed
avrdude-slic3r: safemode: Fuses OK (E:FD, H:D0, L:FF)
avrdude-slic3r done.  Thank you.
Posted : 13/05/2026 7:03 pm
You *might* have a corrupt file so download again but this time first do a factory reset to clear out any legacy settings that could confuse the issue.
https://help.prusa3d.com/article/factory-reset-mk2s-mk2-5s-mk3s_2216
Posted : 13/05/2026 11:20 pm
Hydrohydra
(@hydrohydra)
RE: Flashing error
I have tried redownloading the file, same issue. Since this printer I believe may have started as a mk3 converted to an MK3S printer, it has upgrades applied to it regarding "auto bed level and filament registrering to extruder", the previous owner mentioned an upgrade from mmu2 to mmu2s. (it doesn't have MMU now), He also said he "ran octoprint on it" . I am worried if I factory reset it I will make it no longer work.
Posted : 14/05/2026 9:42 am
The reset is safe - you will then need to flash the MK3s firmware to make it fully usable - for full peace of mind I would run through all the  checks and configurations that are normally the completion of the kit-build process:
https://help.prusa3d.com/guide/9-preflight-check_36224#36232
And if you hit difficulties, as long as this is a genuine Prusa printer and not a Chinese clone, Prusa Support will help via chat.
It may also help to read: https://help.prusa3d.com/article/firmware-updating-issues-mk2-5s-mk3s-mmu2s-mmu3_2225
Posted : 14/05/2026 12:50 pm
