Firmware update fails
I have a MK2.5 Prusa but can't update the firmware.
I tried loading the new firmware (prusa3d_win_2_2_6) but when it was finished the printer just had a very load alarm. I tried turning it on and off and the alarm persisted. I re-flashed again but got the same problem. I flashed the previous firmware (prusa3d_win_2_2_4) and it seemed to be fine. I retried the flash with the new firmware with the same result. So, I reloaded the latest software (prusa3d_fw_3_7_1_MK25) and tried the re-flash again with the same result. I went back to the earlier version and it seems to be fine. Can anyone help?
RE: Firmware update fails
I'm Confused.
Isn't prusa3d_win_2_2_6 Drivers that you would install on your PC (Personal Confuser) and the file prusa3d_fw_3_7_1_MK25 the Firmware that you would flash to the printer.
Are you using PrusaSlicer (or Slic3R Prusa Edition) to flash, if so how are you flashing something other than a .hex file? win_2_2_6 is an .exe file
Peace, Love & Applesauce.
You are correct. I was using prusa3d_fw_3_7_1_MK25 to flash the Prusa. But..... I picked the wrong RAMBO board version. I selected version 10a and my board is 13a. Although I haven't had time to try it yet I am sure that will fix the problem. Thanks for keeping my honest.
Cheers,
Just Bob
