Firmware 3.2.1-FINAL for Original Prusa i3 MK3
Seite 4 / 4
Re: Firmware 3.2.1 for Original Prusa i3 MK3
3.3.0-RC1 was released today.
The time remaining estimates are most welcome!
Veröffentlicht : 27/06/2018 11:01 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Time remaining estimate is implemented in the latest FW, but our Slic3r team has to make some extra coding to make it all work 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 28/06/2018 9:53 am
Protoncek
(@protoncek)
Great! I'm looking forward to it!
BTW.. you mention that you fixed some crash detections and similar. Is this in any way connected with the fact that i've had quite some failed bed levelings at the beginning of the print with version 3.2.1? Each time leveling went fine second time after i reset the printer. I think this fails might happen when printer was hot (second print)...
Veröffentlicht : 28/06/2018 10:14 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Not sure if there is some direct/indirect connection, I asked our FW devs 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 28/06/2018 10:21 am
Protoncek
(@protoncek)
Thanks!
some days ago i've read elsewhere about pinda, preheating, cooling etc... i think guys were talking exactly in the case when pinda is already hot from previous print and this can cause wrong leveling... and they tried something to wait for pinda to cool...is this now implemented in 3.3.0 or was this only a study..?
Veröffentlicht : 28/06/2018 10:30 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Re: Firmware 3.3.0-RC1 for Original Prusa i3 MK3
Regarding the preheating/cooling, there is a thermistor in the MK3 measuring temps and should compensate for the differences.
Assembly manuals
/ Knowledge Base
Veröffentlicht : 28/06/2018 1:09 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
UPDATE: Firmware 3.3.0-RC1 for Original Prusa i3 MK2.5 just released!
More here: https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/firmware-3-3-0-for-original-prusa-i3-mk3-t22743.html#p95936
Assembly manuals
/ Knowledge Base
Veröffentlicht : 28/06/2018 1:10 pm
josh.w3
(@josh-w3)
Marek/Jakub,
Can you please start new threads for a new firmware.
Agreed, another vote for this. It's rather confusing. Would be very helpful to separate the discussions into a new post for each significant FW release.
Thanks for the continued development work!
Veröffentlicht : 01/07/2018 8:55 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
@chris.n6, @webshadow, @josh.w3
Guys thanks for the feedback, noted.
Assembly manuals
/ Knowledge Base
Veröffentlicht : 02/07/2018 1:22 pm
umar.d
(@umar-d)
Re: Firmware 3.2.1-FINAL for Original Prusa i3 MK3
Someone mentioned a permission denied issue.
A complete Hack to just get over this stage is to see which device your Prusa in on (as shown in the Sli3er Firmware Flasher menu and allow everyone to read and write to it:
like:
sudo chmod o+rw /dev/ttyACM0
then revert:
sudo chmod o-rw /dev/ttyACM0
replace /dev/ttyACM0 with whichever device your linux calls it.
Veröffentlicht : 04/10/2018 11:01 pm
aidan.g3
(@aidan-g3)
Running slic3r as an admin solved this problem for me. Here is what I did:
- download the appimage
- extract the appimage in the terminal. From the directory with the appimage
./Slic3rPE-1.42.0-alpha5+linux64-full-201902041815.AppImage --appimage-extract
- then you go into the /squashfs-root directory which is created
- then run "sudo ./AppRun
Veröffentlicht : 09/02/2019 9:28 pm
Seite 4 / 4
