        Firmware 3.9.0 problem manual extrude
Hello,
Is it possible that the manual way to extrude filament is broken? The first time I manual extrude it works, but the second time not. It works again if I change the amount of mm. Then it works again for one time. I need this function to work with the palette 2.
Thanks
                            Posted : 23/05/2020 6:45 am
