Filament Sensor problems
Hub0001
(@hub0001)
Further filament sensor problems.
Did the latest software upgrade.
Right after filament sensor showed disabled,
Ran the wizard again and the filament sensor show wiring problems on screen/ Nothing was changed . Was functioning before flashing latest firmware. Now getting setup failed message on LCD SCREEN.
All other checks are ok.
Possible sensor failure or something else. Printer not even 3 days old.
Opublikowany : 12/03/2019 11:43 pm
Re: Filament Sensor problems
Check the version you flashed: 3.6.0_MK3 or 3.6.0_MKS ... makes a difference.
Opublikowany : 13/03/2019 2:05 am
