filament sensor MK3
Kenork
(@kenork)
filament sensor MK3
Hello, the filament sensor of my MK3 does not work anymore (it used to work for 3 years). I checked cables, it was not wired properly after I changed the einsy card, I corrected the wiring but it still does not work. Maybe the bad wiring destroyed the sensor ? I wanted to change it but I see it is not for sell anymore for the MK3. Is anyone can help me ?
Thanks for your help
Opublikowany : 07/08/2023 11:01 am
Have you cleaned the sensor and it's path of filament strings, dust etc?
Opublikowany : 07/08/2023 2:45 pm
Kenork
(@kenork)
RE: filament sensor MK3
tx for the fast answer ! I did not clean. And when I wanted to do it and read the assemply book, I realise that there is no filament idler anymore. Maybe this is why ? I want to print one but I cannot find the stl model for the MK3.
tx
Opublikowany : 07/08/2023 7:10 pm
if the idler is missing, I expect that the bondtech idler, bearings and bearing shaft are also missing along with the three screws which locate the idler and the two springs which tension the idler.
Idler printable part
https://www.printables.com/model/88240-i3-mk3-printable-parts/files#preview:file-vCNHT
Bondtech gears   Either
https://www.prusa3d.com/product/bondtech-drivegear-set/      (you would also need two thin square nuts for the prusa option)
Or
https://www.ebay.co.uk/itm/225581205115?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111451%26meid%3Df878b6002b2a4636b7727a6ab03aa3a1%26pid%3D101196%26rk%3D3%26rkt%3D4%26sd%3D225302453319%26itm%3D225581205115%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bAndUBSourceDemotionWithUltimatelyBoughtOfCoviewV1%26brand%3DUnbranded&_trksid=p2047675.c101196.m2219&amdata=cksum%3A225581205115f878b6002b2a4636b7727a6ab03aa3a1%7Cenc%3AAQAIAAABQPzGgyhK8D4QCApcBuWVQe1qsoN395NgJVWTF7eo2rfipPwdfCio0EI4F5H%252Bx0wtS8%252Fu%252Fr%252FRUxEZ1KxNtbAGuwQqNawa9Mz45LW45pYy0nuj1HkeVNclKifEtQgOKvKVlinh3kjnR4nEmFK8Si1ortNrUmI9An9Htyhh37QZ2%252FB5fPg3VaRi0lQmprmTBAHiJ%252FaKmC%252FBSE7qKwdYrtCLWDAB2MGBajgQDup53dcYvI7OlcwPIyPldnPr15DgW6t9ZfJogMId60HhilRi%252Bjs%252FIUyLdF%252FPn3%252BBfnelx3wlD9MhpLs7BMpaEGPlVRG6jtMTwwW5wacDKJaHaoFifCAtFoC4TJBDfHXrfQqmmEVUCQ2O0uzR591sHqPSmPG98ICAWF46eAezOTodokdxP0Aujct1cRiYbPdD67c%252FMpZr1jS8%7Campid%3APL_CLK%7Cclp%3A2047675
Extruder Idler springs   Either
https://www.prusa3d.com/product/idler-spring/
OR
https://www.ebay.co.uk/itm/324419328355?hash=item4b88e61963:g:FUQAAOSw4xVet~ry&amdata=enc%3AAQAIAAAA0HIrDwcTvJBr9gN4f597KMkOQXG4c6GVxZQmPSUEznFW7aCv18WA0Yyc0bYP%2Fc5f4NL9zoEfCH71VEpF5IHXiSuiSjRN7bs86nxhvSM8vvendeC831%2F3CD2zjCh6fzs7BMvt%2BSyGaIkn3ft%2BMmO4m%2BWWXpZAtPwoL87DgReOimzrZjVHxo18OozkRuG7ws7dEpnMGxzoiZFQi1QDaTVu%2FSjPehsE0snKYPZIy1%2FX8062kDxplyBHcuGEj2Z0MhHprQ2nXYfE7sy3CLAUnN7QTB8%3D%7Ctkp%3ABk9SR7zIjce6Yg
Mounting Screws  Either
https://www.prusa3d.com/product/mk3s-fasteners-spare-bag-2/     (YOU WOULD PROBABLY NEED 2 PACKS BECAUSE THERE ARE ONLY 2 m3X40 SCREWS AND YOU PROBABLY NEED THREE)
Or
https://www.ebay.co.uk/itm/383632777601?hash=item59524ba181:g:1zwAAOSwjVFfDgnq&amdata=enc%3AAQAIAAAA4KzKKq1qKNhQjclBJyzNLPkMSBY2XnI0U8DYvXRrTMyedNNIsVTkFWgRzLglVP2RMPQiBAPxYTmMs%2FuqfTAiGxxAWmfHJyWQ4VBmCnpAqGlED9%2BAZAqPF7Gy71onfMrXxHSpJXGHadL7XmVhEWaO%2FHIOKaUgnO5jt1IOG0%2B%2B6hvNdj8yv0%2BSiVosd5LbHxI1qqAJCGlxLbkgsMB3O8H0PWgt8NVOVKzRdlu56eF4H%2Bt2weBrGw0wVxOR2lKNqj55nq5LFC35kXm7K4eeOgcB9elRB56Vi6uUCryf5r42vnmb%7Ctkp%3ABk9SR4D-ose6Yg
I hope this helps,
Opublikowany : 08/08/2023 9:32 am
