filament not loading
Hi
I had a print job on my I3 MK3 running out of filament. After i canceled the job I am not able to load new filament.
If I plug in new filament, the filament wheels load my filament for a short time and then run back.
I thought that there is filament remaining under the wheel, but also with heating up the extruder and trying to push it out while pressing it with the new filament, nothing comes out the nozzle.
Did anybody hade the same issue or a solution for it?
Or should I just try to but it out with a small needle or guitar string?
Is there a way to demount the extruder/filament unit to clean it?
BR
Napsal : 28/08/2019 8:26 pm
