filament comes out hair thin and doesn't stick to bed
sembrewery
(@sembrewery)
I have been having the problem of the filament PLA and PETG coming out hair thin. I have been watching the filament come out and the filament just hangs in the air as the X axis moves, and then the filament just drops onto the bed thus it doesn't stick. I have adjusted the Live adjust Z down to -1.570 then run first First Layer Cal.
I have the original Prusa i3 mk3 printer using a 0.4 nozzle running firmware 3.10.1-4697. Im afraid to turn down the Live Z anymore as the  pinda now just skims over the filament.
Also the filament comes right off the HOT bed since the filament isn't squishing onto the bed. I've done a factory reset but nothing changes. I am absolutely new at this 3d printing, and most of the time I have no idea what people are talking about. If anyone can help, please, please, please talk to me in newby talk or I won't know where to look and what to adjust to how much. I've been trying to do a lot of reading, but it is a slow learn.
Thanks for any help you can give me. I'll also try to answer any question you may have.
Mike
Opublikowany : 01/07/2022 10:14 pm
Either you are the first user to lay hands on an XL or you are posting in the wrong forum - you will get better help in the forum for your printer - but Z calibration can go as low as -2 before you need to adjust the PINDA.
Opublikowany : 02/07/2022 10:37 am
RE: filament comes out hair thin and doesn't stick to bed
I Have moved the thread, as the op clearly has a mk3 series printer
Opublikowany : 02/07/2022 1:22 pm
