Extruder moving to the side after each layer
Miquel Adell
(@miquel-adell)
I'm trying to print a very small rod (3mm diameter) on the prusa mk3 and the extruder is printing each layer and then moving to the side.
I sliced the thing in slic3r with the default 0.2mm settings
I'm not sure if this happened before and I just didn't notice because it took a while to complete each layer and I'm just noticing now because it takes seconds per layer or what…
Did any of you notice that?
The part is reeeeeally uneven and I don't see how all this moving arround is helping the accuracy at all
thanks!
Posted : 22/05/2018 11:18 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Extruder moving to the side after each layer
I think that your printer is doing that due to the minimal layer time set in your slicer.
Posted : 22/05/2018 11:21 pm
Miquel Adell
(@miquel-adell)
wop, that was caused by octolapse, a plugin to capture timelapses I just isntaled on octoprint.
Sorry!
Posted : 23/05/2018 1:04 pm
