Extruder motor overheating
Mark
 Mark
(@mark-7)
After running for about two hours, the motor gets too hot to touch.  If I had to estimate, it's somewhere between 80 and 100 degrees.  I'm concerned for the longevity of the motor and did not find a potentiometer near the plugin spot on the board.
It is a MK3S+ that I got near the start of March
Posted : 22/04/2021 1:14 am
Dan Rogers
(@dan-rogers)
RE: Extruder motor overheating
They do get hot.  When I close the enclosure door, even hotter.   There are some mods you can do that add a wrap around fan across the motor - but they add a lot of mass to the print head, which is not great for your print quality...
Posted : 22/04/2021 5:35 am
