Extra extrusion after color change
Djeez2
(@djeez2)
Newbie here.
When switching colors in a print I see the following behavior:
  • After unloading first color and inserting new color I get I little bit of extrusion to get the new color ready. This looks normal.
  • Then on the question "was the correct color extruded", I reply Yes.
  • Then the head moves to the workpiece and immediately starts extruding while moving
This leads to a lot of misprints. My only remedy is while the head is moving trying to get as much filament out of way as possible.
Do I use the correct procedure? Why the extra extrusion?
(Brand new Mk3S+, PrusaSlice 2.4.2)
Dieses Thema wurde geändert Vor 3 months von Djeez2
Veröffentlicht : 01/07/2022 5:24 pm
Zoltan
(@zoltan)
Moderator
RE: Extra extrusion after color change
Can you attach a short video and more information?
Standard I3 mk3s, FW 3.10.1 RC1, MMU2S, no closed box, Fusion 360, PrusaSlicer, Windows 10
PRUSA MINI FW 4.3.4, Prusa Connect Beta
Veröffentlicht : 01/07/2022 7:23 pm
Moderator
When the printer purges the old colour, resist the urge to pull the filament off the nozzle.just hold it still, reply YES the filament is clear. And the print head will move back to the model. Pulling all of the waste off the nozzle, as it.
Good luck. Joan
 goes.
Veröffentlicht : 01/07/2022 8:13 pm
fuchsr
(@fuchsr)
It's by design. It's to repressurize the hotend in case you walked away and didn't immediately press the yes button. As Joan said, needle nosed pliers are your best friend. Just press yes and then hold on to the small piece of filament extruding.
Veröffentlicht : 01/07/2022 10:36 pm
Djeez2
(@djeez2)
Here is a video to show the problem: color switch video
Posted by: @zoltan
Veröffentlicht : 03/07/2022 10:19 am
