Experiencing uneven layers
Recently my Prusa i3 MK3S hasn't been performing up to the quality standard it did when I first got the kit and assembled it. I've printed quite a bit in the 6 months I've owned it, and it's starting to show issues of uneven layers.
I re-did the calibration wizard, I checked the tension of the belts, replaced the nozzle, made sure the hot end was secure, adjusted the extruder gear tension, replaced the PTFE tube, etc. I feel like I've done everything to fix this issue, but it's still happening regardless of the filament or slicer I use.
I've attached pictures to show the issue. I feel at a loss and am not sure what to do.
RE: Experiencing uneven layers
did you check the over all machine for screw tension (loose screws)?
The Filament Whisperer
I tightened everything I could... Unfortunately I'm still experiencing issues. I'm not really sure what to do.
Me either from here, all in all it doesn't look terrible, but theirs so many things it could be, from the surface its sitting on to a firmware update.
have you tried slowing the print down and see if that has an effect? it could even be a specific print, have you been experiencing the problem with a variety of prints or do you keep trying the same one?
