Erratic MK3S+ behavior when Prusalink is active and filament change is requested from console
BoBaCool
(@bobacool)
Strange Scenario :
- power on printer running 3.13.2 os and raspberry Pi3B running prusalink
- connections established properly, links operating
- filament properly ejected using the  control panel on the printer
- confirmed ejected "yes" at the prompt
- change color procedure started unexpectedly...
- extruder moving to the Z top most and right X most position ...
- prompted to eject filament (was already ejected)
- confirmed OK and ejected YES at the prompt
- inserting other filament, nothing happens ...
At this point, only one way to get everything working back properly : power off prusalink pi and restart printer, and use the SD card instead of prusalink ... ???
Any idea  ?
Remark : when using prusalink and no filament change is needed, everything is working properly.
Postato : 16/11/2023 2:19 pm
