Endless Pause cycle
bobnicks
(@bobnicks)
Endless Pause cycle
I've tried on a couple of parts to insert a pause (for the insertion of hex nuts). In all attempts the pause itself works fine. When I Resume Print the printer warms the hotend and moves back to the location on the part where it should pickup the process, then acts like it immediately got another pause command. I've attempted to Resume Print numerous times all with the same result. I tried using the change color as I saw someone suggest and that works but it puts the print head in front of the work and I have to go through the unloading and loading process which is a waste of time. Suggestions? (I have the latest version of software.) MK3
This topic was modified 5 years ago 2 times by bobnicks
Posted : 12/05/2020 1:09 am
RE: Endless Pause cycle
Hi Bob,
Have a look at this video
there are a couple of options discussed.
Regards Joan
Posted : 12/05/2020 2:06 am
Roger
(@roger-3)
I've got exactly the same problem. I'm using the MMU2 and it does what you describe. Clearly the pause is being acted upon correctly, but the printer firmware isn't moving the program pointer onto the next line. That means as soon as it resumes, it repeats the pause command.
Can someone at Prusa take a look at this please, it's clearly a bug with a trivial fix.
This post was modified 5 years ago by Roger
Posted : 12/05/2020 10:25 pm
@roger-f5
Maybe you give 3.9.0 RC3 a try -> https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.9.0-RC3
Posted : 12/05/2020 11:00 pm
bobnicks
(@bobnicks)
@karl-herbert
Thank you. I did locate a post that said this was fixed in the up coming 3.9.0-RC code. As a newbee, I'm not yet brave enough to test RC code on my new toy. I can wait a week or two. Knowing that it is not me doing something wrong and that a fix is coming is adequate for now.
Posted : 12/05/2020 11:06 pm
Roger
(@roger-3)
Hopefully this new release will address that massive blob that the extruder always outputs when starting a print when you're using the MMU2 in Single mode!
Posted : 13/05/2020 10:38 pm
