					                		Earthing problem since firmware 3.12.2 on MK3s - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/earthing-problem-since-firmware-3-12-2-on-mk3s/</link>
                <lastBuildDate>Fri, 15 May 2026 07:50:55 +0000</lastBuildDate>
                        <title>RE: Earthing problem since firmware 3.12.2 on MK3s</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/earthing-problem-since-firmware-3-12-2-on-mk3s/#post-658987</link>
                        <pubDate>Sat, 03 Jun 2023 20:45:53 +0000</pubDate>
                        <description><![CDATA[Earthing is no firmware feature. You should check the conductivity of your PE and the insulation of the other cables.]]></description>
                        <content:encoded><![CDATA[<p>Earthing is no firmware feature. You should check the conductivity of your PE and the insulation of the other cables.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Lichtjaeger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/earthing-problem-since-firmware-3-12-2-on-mk3s/#post-658987</guid>
                        <title>Earthing problem since firmware 3.12.2 on MK3s</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/earthing-problem-since-firmware-3-12-2-on-mk3s/#post-658880</link>
                        <pubDate>Fri, 02 Jun 2023 20:13:25 +0000</pubDate>
                        <description><![CDATA[Ever since I &quot;upgraded&quot; the firmware to 3.12.2 on my MK3S if I touch any metal part while it is printing it acts as if there was a power failure and restarts. I had to disable the thermal te...]]></description>
                        <content:encoded><![CDATA[<p>Ever since I "upgraded" the firmware to 3.12.2 on my MK3S if I touch any metal part while it is printing it acts as if there was a power failure and restarts. I had to disable the thermal test otherwise I could not print anything and now this. Should I backtrack the firmware to the previous version?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>nightlurker</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/earthing-problem-since-firmware-3-12-2-on-mk3s/#post-658880</guid>
