E3D Replacement Heater Cartridge
Danique
(@danique)
So I did exactly what I wasn’t supposed to do and accidentally hit the heater cartridge wire with the adjustable wrench when I was trying to change the nozzle.  I’ve ordered the new part but I’m not sure if I need to take apart the hot end in order to replace it.  I did put it together but this part was already assembled with the kit.
Posted : 28/05/2019 4:43 pm
vintagepc
(@vintagepc)
RE: E3D Replacement Heater Cartridge
You should be able to get at the setscrew that holds the heater in without disassembly; you will, however, have to disassemble the wiring to the extruder to re-run the new cables.
Posted : 28/05/2019 5:20 pm
