drop to bed feature
sembrewery
(@sembrewery)
drop to bed feature
I have two objects on the slicer bed. I want to place one of the objects on top of the other and print them out as one, BUT, both of them drop to bed and so I cannot place one on top of the other. I need to remove this drop to bed feature to do this. is there a way to turn off this feature and then turn it back on? Thanks for any help you can give me.
Mike
Napsal : 29/04/2022 12:33 am
Swiss_Cheese
(@swiss_cheese)
@sembrewery
Select both objects, right click on the pair of selected objects  and select "Merge" from the resulting menu. then on the Sidebar, in the object menu highlight the part you want to place on top and move it to position.
Regards
Swiss_Cheese
The Filament Whisperer
Napsal : 29/04/2022 2:39 am
towlerg
(@towlerg)
RE: drop to bed feature
Posted by: @swiss_cheese
@sembrewery
Regards
Swiss_Cheese
Is it possible to move one of the objects in the Z plane?
Napsal : 29/04/2022 9:09 am
Swiss_Cheese
(@swiss_cheese)
@towlerg
Not an object, only a part.
Regards
Swiss_Cheese
Napsal : 29/04/2022 1:56 pm
Enter the vales in the Pert manipulation pane.
Napsal : 29/04/2022 2:10 pm
1 lidem se líbí
Swiss_Cheese
(@swiss_cheese)
You can also use a gizmo.
Napsal : 29/04/2022 2:15 pm
1 lidem se líbí
sembrewery
(@sembrewery)
I appreciate you quick reply to my question. And your fix to this worked perfectly. I am new to the 3d printer world and I am learning how to do things. Thanks swiss-cheese.
Napsal : 29/04/2022 2:22 pm
Swiss_Cheese
(@swiss_cheese)
Glad I could help.
Napsal : 30/04/2022 5:18 am
