Disable printer beeps
andyeb
(@andyeb)
Is it possible to temporarily disable the printer beeps - particularly the loud ones when loading & unloading filament?
This amazing i3 mk3 is now quiet enough to print in the evenings when my kids are in bed, but the beeps are a problem!
Many thanks,
Andrew
Respondido : 19/04/2018 11:14 am
Re: Disable printer beeps
Bluetac in the sounder?
Or desolder the sounder.
Or put a switch in the sounder circuit..
Regards Joan
Respondido : 19/04/2018 12:37 pm
Kai
 Kai
(@kai-2)
I did it the simple way. A piece duct tape on the beeper.
You can also desolder the beeper , connect it to a switch an solder it back to the board.
Then you have your temporarily disabled printer.
You may also solder a small breakoutboard with a switch.
Many scopes to choose.
nec aspera terrent
Respondido : 19/04/2018 1:19 pm
andyeb
(@andyeb)
Thanks. I guess I was thinking along the lines of something less permanent that would hopefully leave my warranty intact.
Being a software engineer by trade, I might look into seeing if there's a switch that can be flipped in the firmware.
I was thinking I must be missing a menu option or something equally obvious!
Respondido : 19/04/2018 3:04 pm
Kai
 Kai
(@kai-2)
I bet you can control the beeper voltage somewhere/somehow.
But i fear it´s not that simple. It may require some additional Hardware to control it.
I thought about using a potentiometer, but ended up using a small bit of duct tape.
It significantly reduced the sound level.
nec aspera terrent
Respondido : 19/04/2018 3:34 pm
andyeb
(@andyeb)
Sounds like that could be a good interim solution. Thing is, I'd really like a LOUD beep when the printer has run out of filament, but not when I'm loading/unloading and right in front of it.
Respondido : 19/04/2018 3:43 pm
Kai
 Kai
(@kai-2)
I know what you mean.
It would be nice to have presets or "tweakable" values for different operations.
nec aspera terrent
Respondido : 19/04/2018 4:08 pm
neil.e
(@neil-e)
The question has come up before, if you search the forum hopefully you can find the past thread on it. There's nothing built into the firmware but I vaguely recall someone added it themselves to the code once.
Respondido : 19/04/2018 9:46 pm
Olef
 Olef
(@olef)
The same raucous sounder is used on RAID boards, and many times I have had to take steps to shut one up without altering or damaging the board. Blu-Tac is indeed your friend 🙂
Respondido : 20/04/2018 1:17 am
eb3dprints
(@eb3dprints)
I am a newb, can someone point me to a picture of where the sounder is so I can tape it?
Thanks!
Respondido : 08/06/2018 1:25 am
Hi Erin,
Welcome
Respondido : 08/06/2018 1:54 am
eb3dprints
(@eb3dprints)
My ears thank you! This gcode print with noises in it scared me so bad earlier D:
Respondido : 08/06/2018 5:51 am
Area51
(@area51)
Miembro
The beep issue has been reported in the Prusa firmware section, read more here on github, issue #478
Respondido : 10/06/2018 1:03 pm
kbx
 kbx
(@kbx)
I hope providing a feature to turn the beeping off is in the plans. I get my kit on Friday and this was the second thing I thought of. Soldering a switch to a £100 board is a bit different to soldering a £12 Raspberry Pi Zero.
Respondido : 10/07/2018 10:32 pm
Rakayne
(@rakayne)
I assume this still hasn't been addressed. The beep is just too loud! I would rather not use tape to cover the speaker.
Respondido : 10/09/2018 7:27 am
New firmware releases will provide the ability to mute beeps. There's an RC out now and the final should be released soon.
Respondido : 10/09/2018 7:39 am
