Did I download the correct 'printable upgrade files'? What's up with the shroud?
I am trying to upgrade my Mk3s. I am pretty sure I downloaded the correct parts. The fan shroud looked a little fishy in Prusaslicer however so I checked it in the 3d viewer that they have posted online. I have attached a few screenshots (make sure to click to see full uncropped photo) of the part that I downloaded here side-by-side with the Shroud as it appears in the latest online 3d viewer version here. Which is the correct shroud and does anyone know the reason for the discrepancy?
RE: Did I download the correct 'printable upgrade files'? What's up with the shroud?
the Dam, at the front, is a removable support Print it, and remove the u shaped bit which supports the edges of the duct outlets
Oh I see, I'll bet that is in the instructions I have not yet read. Thank you.
