CPE Material, 0.6 nozzle first layer under-extrusion - How to solve?
Hello,
I'm having an issue with PrusaSlicer-2.3.1 I'm trying to print a big object (the size should not matter at all) with the following settings:
Material is CPE
Configuration is 0.30 mm draft
Nozzle diameter is 0.6 mm
With this settings the total printing time is 11 hours which is not bad at all. BUT. For an unkown reason, the first layer is under-extruded. I've seen in the Slic3r that flow for the first layer is 0.840 and for the second layer goes up to 4.5 minimum and 8.3 maximum which is OK.
I understand the second layer is .3 mm and the first one should be 0.2 mm but if you see how the first layer is printed you cleanly see it is under-extruded.
Is there a way to modify extrusion flow only for the first layer (other than editing the gcode by hand)
Thanks!
I don't know how to adjust this in the Slic3r, I think it is a bug somewhere in the code.
