Conditional gcode syntax in Slic3rPE 1.41.1
I'm trying to use conditional gcode syntax as described in the release notes for 1.38.2. I'm trying to generate a temperature calibration tower using the following syntax:
;BEFORE_LAYER_CHANGE
G92 E0.0
;layer_z is height of current layer in mm
;[layer_z]
{if layer_z == 91.6}M104 S220
{elseif layer_z == 81.6}M104 S225
{elseif layer_z == 71.6}M104 S230
{elseif layer_z == 61.6}M104 S235
{elseif layer_z == 51.6}M104 S240
{elseif layer_z == 41.6}M104 S245
{elseif layer_z == 31.6}M104 S250
{elseif layer_z == 21.6}M104 S255
{elseif layer_z == 11.6}M104 S260
{elseif layer_z == 1.6}M104 S265
{endif}
Attempts to generate gcode result in the following:
!!!!! Failed to process the custom G-code template before_layer_gcode
Parsing error at line 6: Not a variable name
!!!!! End of an error report for the custom G-code template before_layer_gcode
I've tried combining all of the lines into a single line with no better luck. This works, but is much more cumbersome:
; layer_z is height of current layer in mm
G92 E0.0
;[layer_z]
{if layer_z == 91.6}M104 S220{endif}
{if layer_z == 81.6}M104 S225{endif}
{if layer_z == 71.6}M104 S230{endif}
{if layer_z == 61.6}M104 S235{endif}
{if layer_z == 51.6}M104 S240{endif}
{if layer_z == 41.6}M104 S245{endif}
{if layer_z == 31.6}M104 S250{endif}
{if layer_z == 21.6}M104 S255{endif}
{if layer_z == 11.6}M104 S260{endif}
{if layer_z == 1.6}M104 S265{endif
Am I misunderstanding how elseif should work? I know Slic3rPE uses a different syntax from mainstream Slic3r.
Posted : 29/10/2018 7:11 pm
Peter in Katy
(@peter-in-katy)
Re: Conditional gcode syntax in Slic3rPE 1.41.1
The post you referenced had the conditional as
elsif
Not elseif.
{if condition1} text on condition1 {elsif condition2} text on condition2 {else} text on else {endif}
Posted : 29/10/2018 11:10 pm
elsif
Not elseif.
Hah! That was it. I've encountered both "elseif" and "elif" before and I guess my mind was doing auto-correct. I've never seen "elsif" before. Made the change and all is working perfectly now. Thanks!
Posted : 30/10/2018 2:24 am
Peter in Katy
(@peter-in-katy)
Glad I could help.
It took me a couple looks to 'see' the error.
If I had a dime for every minute I've spent starting at code that should just work...
Posted : 30/10/2018 2:59 am
