ColorPrint App doesn't work
Chris
(@chris-21)
I've been trying to use the ColorApp application that comes with the driver downloads and have not been able to do so.
Each time I try to add my gcode files I get the error messages:
From time to time I'll be able to get a gcode loaded into the app and I'll get to the layer details, but when I do regardless of what number I put in the layer height for any layer is set to 0.20.
I tried to look for the app on the josephprusa github account but couldn't find the source to dig in.
Is there a fix for this?
I'm running on a:
- MacBook Pro (Retina, 15-inch, Mid 2015)
- 2.5 GHz Intel Core i7 processor
- macOS Serria version 10.12.6
Posted : 23/05/2018 1:41 am
stephen.h14
(@stephen-h14)
Re: ColorPrint App doesn't work
I just used ColorPrint myself, worked ok for me? Your screen shot looks different than mine but I use a PC, I went to https://www.prusaprinters.org/color-print/
Is it different because of the Mac?
Posted : 23/05/2018 4:12 am
josh.w3
(@josh-w3)
I have never been able to get the local ColorPrint Application to work correctly on a Mac. So I have always relied on the ColorPrint website for making color changes in my gcode. Unfortunately the website is now no longer working with gcode produced by Slic3r 1.39.2. Someone suggested using PrusaControl, in the mean time, but I haven't tried it yet.
Posted : 23/05/2018 4:52 am
Christopher
(@christopher-5)
I couldnt get the Prusa ColorPrint Webbased Version to work since Slic3r 1.39.2.
There is no local based ColorPrint I don't think
ColorPrint is intergrated into PrusaControl, I have been using that, works good.
Posted : 23/05/2018 7:23 am
Erik
 Erik
(@erik-3)
A work around in the meantime is to add the M600 code manually. I search for ;{Layer_Height} and find the SECOND one that is marked as "AFTER_LAYER_CHANGE" in the comments. Then I skip all of the prep gcode and drop the M600 just before the first movement comment where plastic is extruded. The last command before the M600 is usually G1 F1500. Sure, it's a manual process, but it works just the same. Here's an example:
;BEFORE_LAYER_CHANGE
;1.2
G1 F12000
G1 X133.095 Y102.168 E-0.05789
G1 F12000
G1 X133.595 Y101.993 E-0.08796
G1 F12000
G1 X133.051 Y101.449 E-0.12793
G1 F12000
G1 X133.076 Y100.800 E-0.10795
G1 F12000
G1 X134.238 Y101.963 E-0.27328
G1 E-0.14498 F2100.00000
G1 Z1.600 F15000.000
;AFTER_LAYER_CHANGE
;1.2
G1 X154.422 Y126.973 F15000.000
G1 Z1.200 F15000.000
G1 E0.80000 F2100.00000
G1 F1500
M600
G1 X153.795 Y127.800 E0.03513
Posted : 23/05/2018 2:22 pm
josh.w3
(@josh-w3)
There is a local ColorPrint app, at least on a Mac (can't speak for Windows). If you re-examine the first post you'll see the OP is using it (and not the web version). Unfortunately it's never worked correctly for me. I'm not sure what is the point of including it in the driver package if it's perpetually broken.
Posted : 23/05/2018 4:09 pm
stephen.h14
(@stephen-h14)
I never noticed that! There's a "+" off to the side of the slider that adds the color change. Thanks!
Posted : 23/05/2018 4:22 pm
Chris
(@chris-21)
Thanks for the tip karl.w2. I'll give that a try.
Yeah, I've never been able to get the ColorPrint to work on my mac which is what lead me to seek out a solution and find the website version. That version has worked for me in the past but has since stopped working.
I don't have a windows machine, but I'll see if I can get a friend to run the ColorPrint software for me.
Is there any chance of either ColorPrint being fixed so it works on mac (and so that the website works again) or at least having the software open sourced so it could be fixed?
@karl.w2, is what your describing what the software actually does? If that's it I could crank out an electron version fairly quick.
Posted : 24/05/2018 4:10 pm
What Kark describes is pretty much what happens.
Be aware that the cimmand has a capital M and no gap between M600...
Also be aware that you can get false Z height indications... if Z hop is enabled.
Say you are using 0.2mm layer height. And 0.6mm Z hop.
If you want to invoke folament change at 1.0mm
You would expect to search for Z1.0
Unfortunately this can occur at layer heighr 0.4mm when there is a Z hop the Z height will show Z1.000
What I do. Is make the Zhop 0.62mm and search for Z1.00 this will avoid the Zhop error because the height with Zhop at 0.4mm will be 1.02
Which the search will ignore.
Also be aware. Marlin firmware causes a dribble of filament agter each M600 colourchange.
If you use your long nose pliers to grab the waste filament. BUT DO NOT PULL IT OFF THE EXTRUDER NOZZLE
when the lcd asks if the colour is clear. You click the button. The extruder then squirts out a dribble of filament before moving back to the print
This extra filament is pulled off the extrudwr automatically and does not end up as a booger on your print...
You can then throw away the waste in one piece
Regards Joan
Posted : 24/05/2018 4:51 pm
