Color Print Partially Working
Tdub415
(@tdub415)
There seems to be an issue with the Color Print page currently. If I only have one color change, it works just fine, but if I add multiple color changes, it only inserts the m600 command for the highest layer that has a change. I'm not sure if this is only occuring with simplify3D sliced gcode, or if it's an issue with other flavors of gcode as well.
Posted : 04/02/2019 10:23 am
stephen.h14
(@stephen-h14)
Re: Color Print Partially Working
I'm having the same problem. Only the last M600 code gets inserted. I tried PrusaControl for the color changes and then checked it, all three of my color changes are inserted then. I haven't used ColorPrint for a couple months but it worked fine back then. Not sure why it's not now. On a side note, does anyone know how to insert a color change using Slic3r? I thought I read that this was going to be added but I don't know if it happened yet.
Posted : 18/03/2019 3:59 pm
vintagepc
(@vintagepc)
It is available in the alpha release that's been mentioned here on the forums, but not the mainline 1.41 branch
Posted : 18/03/2019 5:00 pm
stephen.h14
(@stephen-h14)
Ah, ok, that's probably what I remembered reading on here. I'm still on 1.41-something I believe. PrusaControl is working to insert the color changes for now after I generate the code in Slic3r. I usually avoid jumping to any new programs or firmware until it's been tested out a long time, given my skills I don't need any additional variables to deal with! 🙂
Posted : 18/03/2019 11:01 pm
