color change
why dose my printer do a color change when its not in de stl file and dose it fore all the thing it prints Mk3s
RE: color change
The filament sensor could be out of adjustment.
this can happen due to  engineering / printing differences  on the printer, and it can also happen as a printer ages, and the filament path wears larger.
many people find that a spacer washer underneath the filament sensor PCB raises the sensor, just enough to resolve the problem Below are links to two versions that can be found on Thingiverse.
Spacer for Prusa MK3S Filament Sensor
 https://www.thingiverse.com/thing:4665750
 https://www.thingiverse.com/thing:4006603
I Hope one of them works for you.
RE: color change
- Thanks il give it a try
