Cleaning nozzles?
Seite 2 / 2
Mitglied
RE: Cleaning nozzles?
@karl-herbert
Please do.
Veröffentlicht : 27/07/2020 4:52 pm
@charles-h13
Nylon/PEEK nozzlebrush Step data - The hole diameters must be adjusted according to the diameter of the Nylon/PEEK string: nozzlebrush
Veröffentlicht : 27/07/2020 6:09 pm
Jimbo70
(@jimbo70)
I use a toothbrush. You can get them in various stiffness and different quality bristles.
The better brushes will not deform or melt with the heated hot end.
They are cheap and readily available, your drawer may have several old ones, if not use your wives brush - it makes 3D printing more exciting.
Veröffentlicht : 29/07/2020 12:13 am
buckeyestargazer
(@buckeyestargazer)
Posted by: @louis-j
I thought about tooth brushes but then discovered that most are made with nylon-6 which melts at like 220C.
Veröffentlicht : 29/07/2020 1:11 am
jsw
 jsw
(@jsw)
I use an el-cheapo brass wire brush.  I know it's not steel based because it indeed feels kinda soft.  I'm now in the habit, when I begin a print, of checking for worms and 'boogers' and such clinging on the nozzle and brushing them off if needed.
Veröffentlicht : 29/07/2020 1:27 am
buckeyestargazer
(@buckeyestargazer)
Posted by: @karl-herbert
@charles-h13
Thanks for this.  Could you link me to specific nylon string that you use?  I'm just not sure what to get but I want something that won't melt.  Also, what thickness string is appropriate for the "nozzlebrush_0.80" head?
Veröffentlicht : 08/08/2020 12:01 am
@buckeyestargazer
PA6 + PA6.6 Monofilament like this one (different diameters available): https://www.carbonscout-shop.de/Monofilament-PA-6-cord-O-08-mm-length-100-m.html . There are certainly manufacturers in your region.
I would recommend nylon, because PEEK is extremely expensive.
Veröffentlicht : 08/08/2020 2:11 pm
buckeyestargazer
(@buckeyestargazer)
@buckeyestargazer
Got the PA6 mono nylon, but how do you print such tiny holes?!?!
Veröffentlicht : 10/08/2020 7:05 pm
@buckeyestargazer
With a 0.25 nozzle and a well calibrated printer If necessary you can rework the holes with a drill.
Veröffentlicht : 10/08/2020 7:52 pm
Seite 2 / 2
