Can't Upload STL File
Guyzerr
(@guyzerr)
I found a file I liked in the " Prints " section of this site and one particular part needed a modification which I made in Tinkercad.  I imported that STL file into Prusa's latest slicer and saved it both as a gcode and STL file.  When I try and upload the files so they can be used by others it will only accept the gcode file and a message tells me to use the Prusa slicer for the STL file.  I did that already.  How do I upload a STL file to someone elses page.
Posted : 19/06/2021 2:18 am
adesir
(@adesir)
RE: Can't Upload STL File
I think you can not do that. If you have made a modification, you created a "remix", you are the author. So you have to publish your remix, then link to the original print.
Mes modeles publics
Posted : 19/06/2021 7:16 am
