					                		Cant flash MMU fail to connect - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/cant-flash-mmu-fail-to-connect/</link>
                <lastBuildDate>Mon, 08 Jun 2026 02:50:05 +0000</lastBuildDate>
                        <title>RE: Cant flash MMU fail to connect</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/cant-flash-mmu-fail-to-connect/#post-602441</link>
                        <pubDate>Sat, 16 Apr 2022 04:07:33 +0000</pubDate>
                        <description><![CDATA[Try hitting the reset button on the mmu and then, as quick as you can, click the flash button in PrusaSlicer.]]></description>
                        <content:encoded><![CDATA[<p>Try hitting the reset button on the mmu and then, as quick as you can, click the flash button in PrusaSlicer. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>ZombiPach</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/cant-flash-mmu-fail-to-connect/#post-602441</guid>
                        <title>Cant flash MMU fail to connect</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/cant-flash-mmu-fail-to-connect/#post-602207</link>
                        <pubDate>Thu, 14 Apr 2022 09:54:14 +0000</pubDate>
                        <description><![CDATA[I have flashed the mmu before no problem but now it wont connect?   avrdude-slic3r -v -p atmega2560 -c wiring -P COM6 -b 115200 -D -U flash:w:0:C:\Users\kent\Downloads\prusa3d_fw_3_11_0_MK3S...]]></description>
                        <content:encoded><![CDATA[<p>I have flashed the mmu before no problem but now it wont connect? </p><p> </p><p> </p><p>avrdude-slic3r -v -p atmega2560 -c wiring -P COM6 -b 115200 -D -U flash:w:0:C:\Users\kent\Downloads\prusa3d_fw_3_11_0_MK3S_1_0_6_MMU2S\prusa3d_fw_MK3S_MK3S+_3_11_0_4955.hex:i</p><p>avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 10 2022 at 11:54:26 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch</p><p>Using Port : COM6 Using Programmer : wiring Overriding Baud Rate : 115200avrdude-slic3r: stk500v2_recv(): timeoutavrdude-slic3r: stk500v2_getsync(): timeout communicating with programmeravrdude-slic3r: Could not open port: COM6</p><p>avrdude-slic3r done. Thank you.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>kentthoresen</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/cant-flash-mmu-fail-to-connect/#post-602207</guid>
