RE: Can't find Calibration Point
Youre welcome glad we found a solution you can always fix the pinda
if you have a soldering iron
I narrowed it down to the blue wire for the Pinda (See Photo). It broke right at where it meets the plastic support arm that you zip-tie the bundle to. I elected to cut, solder, and heat shrink (See photos) all the wires for the Pinda just in case another wire was broken as well. I will be ordering another just in case this happens again. This fixed the issue and I am back up and running.
