Can't find Calibration Point
Strona 1 / 3
Jonathan
(@jonathan-10)
I just got done printing and went to start another and it can't find the front right corner. I went to do a Z calibration and it can't find the same corner. I then tried the XYZ calibration and in can't find the second calibration point. I flashed it with the new version on 3.11 and it is still having the same issue. I changed the mesh bed setting to more points and it still can't find that corner. I confirmed the pinda is reading the metal sheet. Any help would be amazing.
Best Answer by Jonathan:
The Z calibration completed on the side away from the bad side when the X axis was unplugged. When the printer was moved to the side where it had previously failed, it failed again immediately. This led the me to suspect the Pinda probe, which was found to have a broken wire when the cluster of cables was moved (See video Untitled (6)). A new Pinda will be ordered to fix the issue. Thank you so much @Hello for all your help and the suggestion to unplug the X motor, which led to the solution. Thank you.
Opublikowany : 30/12/2022 4:16 pm
Robin
(@robin)
RE: Can't find Calibration Point
What exactly happens when "it can't find the right corner"? Error message? Behavior shown vs. expected?
Opublikowany : 30/12/2022 4:20 pm
Jonathan
(@jonathan-10)
When I do the Z calibration it gets to the third calibration (front right corner) and gives me this error "Bed leveling failed. Sensor didn't trigger. Debris on nozzle? waiting". When doing the XYZ where you don't use the metal sheet it finds the first point then goes to the second and it can't find it. It slowly moves up while doing little circles. It reaches the top, maxes out, and it keeps trying to go up until I stop it so it doesn't break itself.
Opublikowany : 30/12/2022 4:34 pm
Jonathan
(@jonathan-10)
I just did a factory reset and still nothing.
Opublikowany : 31/12/2022 9:52 pm
Hello
(@hello)
is your bed scewd
Opublikowany : 31/12/2022 9:55 pm
Hello
(@hello)
How old is the printer
and is the magnet missing from heatbed because if there is no meatal for the pinda to recognize then it will not get set off
Opublikowany : 31/12/2022 9:57 pm
Jonathan
(@jonathan-10)
Bed is screwed and tight unless you mean screwed meaning broken but it is now.
Opublikowany : 31/12/2022 10:22 pm
Jonathan
(@jonathan-10)
It's about 5 years old. All magnets are in place. It cant find that corner with the metal sheet for the Z calibration and it cant with the XYZ when the sheet it off. It it very consistent and only that corner for all the tests.
Opublikowany : 31/12/2022 10:24 pm
Hello
(@hello)
i meant skewed sorry for spelling mistake
Opublikowany : 31/12/2022 10:33 pm
Hello
(@hello)
any chance you can take vidio of whole process where it fails and also photo of heat bed without the sheet on Thanks
3Delight
(@3delight)
Moderator Moderator
Have you tried without a steel sheet on the bed and seen if the PINDA probe coming down over the magnets' location? (a dotted circle at the corners.)  If it's not that means that it assembled wrongly.  I discovered this the hard way myself on my previous printer and now always check it on first assembly!
Opublikowany : 31/12/2022 10:34 pm
Hello
(@hello)
Underneath the actual heat bed the one you don't print on there is a magnet can you confirm that is there
Opublikowany : 31/12/2022 10:36 pm
Jonathan
(@jonathan-10)
It's about 5 years old. All magnets are in place. It can't find that corner with the metal sheet for the Z calibration and it can't with the XYZ when the sheet is off. It is very consistent and only that corner for all the tests. It fails on the second calibration point and then it's at the top so it can't find the others and fails. I have hundreds of hours probably 500 hr run time so I don't think it is the assembly.
Opublikowany : 31/12/2022 11:13 pm
Jonathan
(@jonathan-10)
Opublikowany : 31/12/2022 11:17 pm
Jonathan
(@jonathan-10)
I tried to upload a video as a file and media not sure where there went.
Opublikowany : 31/12/2022 11:18 pm
Hello
(@hello)
ok
Opublikowany : 31/12/2022 11:19 pm
Hello
(@hello)
put it into zip file and upload zip
Opublikowany : 31/12/2022 11:20 pm
Jonathan polubić
Jonathan
(@jonathan-10)
Untitled (2)
Hope this video works.
Opublikowany : 31/12/2022 11:23 pm
Hello
(@hello)
yes it worked
Hello
(@hello)
the nozzle dosent even go lower enough thats why its not setting off try do it without paper and start it lower to the bed
Opublikowany : 31/12/2022 11:25 pm
Strona 1 / 3
