Cannot get rid of this noise from the extruder.
mats.l2
(@mats-l2)
This topic was modified 7 years ago by mats.l2
Posted : 22/08/2019 2:48 pm
RE: Cannot get rid of this noise from the extruder.
Video embed did not work.
Posted : 22/08/2019 2:51 pm
mats.l2
(@mats-l2)
https://www.facebook.com/mats.lantz.5/videos/2620876434612293/?t=1
Posted : 22/08/2019 2:55 pm
mats.l2
(@mats-l2)
Can you see this?
Posted : 22/08/2019 2:56 pm
My firewall blocks most all FB domain IP's ... at least the 200 or so addresses I know about.
Posted : 22/08/2019 5:19 pm
mats.l2
(@mats-l2)
Posted : 22/08/2019 5:22 pm
mats.l2
(@mats-l2)
Sorry not possible to upload "awating moderation"
Posted : 22/08/2019 5:23 pm
mats.l2
(@mats-l2)
https://www.dropbox.com/preview/Public/VID_20190821_113113.mp4?role=personal
Posted : 22/08/2019 5:26 pm
Dropbox post is private and requires a dropbox account sign in...
Reverse engineered your first post attempt, you probably unchecked LINK TO MEDIA FILE before inserting.
https://forum.prusa3d.com/wp-content/uploads/2019/08/VID_20190821_113113.mp4
The clicking is probably friction from unlubricated rods and bearings; or a belt that is too tight. Impossible to tell.
Try a few drops of oil on the rods, on each side of the extruder - same with the Y-axis rods, bot sides of the bearings.   Work the bed and extruder back and forth (powered off) to work the oil into and past the grease seals.
Belts should deflect about 1/4 inch minimum with 6 to 8 ounces pressure. 15/64 on X, and 12/64 on Y.
There is a BELT TENSION display on the LCD status menus: useless for adjusting belts, but helpful for looking at friction loads on the motors. What are the numbers on your printer?
There is also a known "squeaking" that occurs when the PTFE tubing is running against the Bondtech gears.
This post was modified 7 years ago by --
Posted : 22/08/2019 9:36 pm
mats.l2
(@mats-l2)
Thanks for the help, lubricated the rods and changed filament from PLA silver to PETG. Much better not completly silent but acceptable.
This post was modified 7 years ago by mats.l2
Posted : 23/08/2019 3:16 pm
