Can I set multiple colors inPrusaslicer on the same plane?
I've seen that Prusaslicer has the option to change colors on different layers, but I wonder if is possible to print different colors on the same layer without changing the filament too often.
Example:
- on the first layers I have a big rectangle that occupies almost all the horizontal printing area
- on the next layer I have diagonally opposed objects small in height
I could potentially print these objects in different colors without changing filament on each layer because the shape of the small object will not interfere with the print head. I could change filament just once when the first small object is done. Prusa slicer could actually detect if the print head is in conflict with an object and find the right path.
Is this possible?
RE: Can I set multiple colors inPrusaslicer on the same plane?
You can print several colors per layer via manual color swap (google prusaslicer multi color print no mmu) but you can't really finish printing one object with one color and then start the next (if that's what I understand you want to do) unless you use sequential printing but that requires each object to be separate from the others.
