Boot stuck on bootloader
CovertPluto3502
(@covertpluto3502-2)
So the other day I turned off the printer for a few days, and tonight when I started it, it was stuck on the first screen at boot. Looks like the firmware has problem loading or the bootloader has problems. Has anyone experienced this and how did you solve it?
FW: 3.9.1 (also tried 3.9.2)
Napsal : 10/12/2020 9:00 pm
RE: Boot stuck on bootloader
Posted by: @covertpluto3502-2
If the printer doesn't want to work anymore, I would do a factory reset and reflash the fw as a first step. Often this helps.
Napsal : 10/12/2020 10:57 pm
towlerg
(@towlerg)
Did you power cycle after the last firmware upgrade?
Napsal : 11/12/2020 12:58 pm
