Bondtech Upgrade worth it?
Hi!
I would like to ask if it's worth it to upgrade the extruder with the Bondtech BMG, the Bondtech Mosquito, something else, or nothing at all?
It is a noticeable print quality improvement
Would be nice some opinions from experienced users.
Best regards!
RE: Bondtech Upgrade worth it?
What are you printing? A mosquito allows to print at higher temperatures and may reduce jams. The bondtech improves print speed. I have never seen the advantage of the bondtech.
@charles-h13
I would like to try the new PC-Blend, and some Filaflex. Maybe Nylon in the future.
But as known they are challenging filaments.
And would like to know, if it's worth it to invest in such an upgrade.
You do not need either. You can print with primary extruder and heated.
