Bed Temp Error only on Small Prints in Middle of Heat Bed
jRadx.Design
(@jradx-design)
Anybody else ran into this problem? When I try printing a single xyz calibration cube in the middle of by print bed I get a bed temp error during the first few layers and the print stops itself. I am thinking this is caused by the nozzle (Heated for PETG) causing the temp sensor underneath the bed to give the temp error, as prints moved away from the middle print fine. Any future ideas of a firmware fix that will check if nozzle is near the bed temp sensor and calculate the temperature of the bed differently than if the nozzle is far away from it? That would be great!
cheers
-Jared
-jRadx
Napsal : 10/05/2019 6:44 pm
A.Dorn
(@a-dorn)
RE: Bed Temp Error only on Small Prints in Middle of Heat Bed
In case you get a "bed preheat error" it might be worth waiting for a fix of the firmware. The current firmware is a bit problematic and might give you pretty random preheat errors. There already is a first release candidate for 3.7.1. Maybe worth a try, or you wait a bit for the final 3.7.1...
Something that worked for me as a workaround was avoiding bed temperature changes by setting the bed temperature for first layer = temperature of other layers.
Napsal : 10/05/2019 7:07 pm
