					                		‘Bed leveling Failed” msg - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/</link>
                <lastBuildDate>Tue, 16 Jun 2026 06:43:22 +0000</lastBuildDate>
                        <title>RE: ‘Bed leveling Failed” msg</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661393</link>
                        <pubDate>Sat, 24 Jun 2023 01:47:54 +0000</pubDate>
                        <description><![CDATA[Well I ended up trying to do a z cal and it worked. I then did a live z cal to get the first layer height corrrct and it then ran a print like normal . However about 3.5 hrs into a 4.5 hr pr...]]></description>
                        <content:encoded><![CDATA[<p>Well I ended up trying to do a z cal and it worked. I then did a live z cal to get the first layer height corrrct and it then ran a print like normal . However about 3.5 hrs into a 4.5 hr print I get a “thermal anomaly msg and this constant beeping but the print continued to completion? I’ll start a new topic about this </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Nimitz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661393</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661329</link>
                        <pubDate>Fri, 23 Jun 2023 15:57:27 +0000</pubDate>
                        <description><![CDATA[Could be a one of the &quot;trapezoidal&quot; nuts is binding on the z axis lead screw.  Try slightly loosening the M3x18 bolts that secure the nut(s) to the x-ends.]]></description>
                        <content:encoded><![CDATA[<p>Could be a one of the "trapezoidal" nuts is binding on the z axis lead screw.  Try slightly loosening the M3x18 bolts that secure the nut(s) to the x-ends.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>ksweir</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661329</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661308</link>
                        <pubDate>Fri, 23 Jun 2023 13:17:04 +0000</pubDate>
                        <description><![CDATA[Thx. So I was able to now get the calibration wizard to start.  It got to the point where it said to put a sheet of paper on the bed then shortly have the nozzle started to descend it stoppe...]]></description>
                        <content:encoded><![CDATA[<p>Thx. So I was able to now get the calibration wizard to start.  It got to the point where it said to put a sheet of paper on the bed then shortly have the nozzle started to descend it stopped withe the msg: calibration failed. Check the axis and run again.</p><p>not sure what to do next? I tried re running the wizard and got to the same point and it stopped.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661308</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661269</link>
                        <pubDate>Fri, 23 Jun 2023 00:13:22 +0000</pubDate>
                        <description><![CDATA[on lcd menu go to calabration then home all aXiS that Should fi your problem]]></description>
                        <content:encoded><![CDATA[<p>on lcd menu go to calabration then home all aXiS that Should fi your problem</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Hello</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661269</guid>
                        <title>‘Bed leveling Failed” msg</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661252</link>
                        <pubDate>Thu, 22 Jun 2023 19:49:44 +0000</pubDate>
                        <description><![CDATA[Been printing a bunch of parts without issue over the last couple of days &amp; when I went to print another part today I got the following msg after the bed had heated to the proper temp &amp;a...]]></description>
                        <content:encoded><![CDATA[<p>Been printing a bunch of parts without issue over the last couple of days &amp; when I went to print another part today I got the following msg after the bed had heated to the proper temp &amp; the nozzle started moving down to begin the bed leveling routine:</p><p>Bed leveling failed. Sensor didn’t trigger. Debris on Nozzle? Waiting</p><p>The nozzle was clear but I unloaded the filament, reloaded and preheated it again &amp; a string of filament came out like normal.  I then restarted the print and the nozzle went down to about 3” from then top of the bed &amp; stopped at the same point, displaying the same msg?</p><p>How do I go about trouble shooting this or does someone know what is causing it?  Thx!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/bed-leveling-failed-msg/#post-661252</guid>
