Bearing replacement guide?
J S
 J S
(@j-s-2)
Is there any guide to removing the bearings? I need to lube mine as they have become very noise and are seizing.  I got the Z axis ones easily but I'm trying to figure out if there's some way to get the bearings out of the head unit without taking half of it apart.
Postato : 22/10/2019 1:27 am
rmm200
(@rmm200)
RE: Bearing replacement guide?
Just remove the 5 screws holding the extruder back cover on.
When you put it back together, do not tighten those screws too tight.
If you have a bearing that is seizing - I would replace it. They are not expensive.
Postato : 22/10/2019 2:36 am
