Bearing replacement guide?
sacihosu
(@sacihosu)
Hello. Is there any guide to removing the bearings? I need to lube mine as they have become very noise and are seizing. I got the Z axis ones easily but I'm trying to figure out if there's some way to get the bearings out of the head unit without taking half of it apart.
If you are aroused by beauties in lingerie then you are here https://thesexygirlsinlingerie.com/
Opublikowany : 04/12/2020 5:36 am
Ferly
(@ferly)
RE: Bearing replacement guide?
I did a little maintenance last week:
Remove z-axis holder at the top
remove x-axis motor
release (dont remove, just release) screws from z-axis motor
slowly turn both z-axis rods so entire x-axis moves upwards, gently pull z-axis to the front so the wiring from the extruder doesnt catch at the frame
carefully remove entire x-axis assembly
once its off the z-axis, remove rear cover of extruder, cut zip ties from extruder bearings and extruder should come off
Hope this helps.
This post was modified 6 years temu by Ferly
Opublikowany : 04/12/2020 10:25 am
